Control a Claw with remote control of Chasing Gladius Mini
Posted: May 13th, 2021, 10:46 am
https://www.youtube.com/embed/GPYWRRsHwDk
Can someone explain how this works? This person bought a BlueROV2 claw/gripper and mounted it on the FiFish V6. I want to do the same for my Gladius Mini. Based on some of the comments, he "piggy backed" the claw mechanism by switching the light up or down. I wanted to know what sort of electronics, PWM or logic board can be used and installed on the Gladius Mini. Some comments on there was to a specific PWM and voltage for the lights to control the claw. Of course the power source would need to be hooked up similar to this mod for the FiFish. The benefit of this is you don't need an extra tether and you don't need a float pod.
Please give us some ideas if you know!
- Electrical Parameters for Claw
Supply Voltage (Vin) 9 - 18 volts
PWM Logic Voltage 3.3 volts
PWM Neutral Signal 1500 µs
PWM Open Signal >1530 µs-1900 µs
PWM Close Signal <1470 µs-1100 µs
Peak Current 6 amps
- As far as components.
Newton Subsea Gripper -> https://bluerobotics.com/.../newton-gripper-asm-r2-rp/
Binder 770 Bulkhead Connector (appears to be it on video not sure)- > https://bluerobotics.com/.../connectors ... -bulkhead/
Custom Bracket for Gladius Mini -> T.B.D
Electronics for LED switching of Claw -> T.B.D
