Penetrator for my ROV max. 100 Meter deep
Posted: Feb 24th, 2021, 5:32 pm
Hey, I'm thinking about to use the Blu Robotic Watertight Enclosure for ROV/AUV (4″ Series)
https://bluerobotics.com/store/watertig ... e4-asm-r1/
So, the first challenge will be to get a water tight connection from the BLDC-Motors inside the Hull.
The Blue Robotics Penetrator are a bit expensive, so I found this Solution on Youtube.
https://www.youtube.com/watch?v=hHHGozByLF8
Has anyone experience with this easy solution? The Guy in the Video told to use single Core wire.
I'm not sure is this needless? Because the Motor-Cable from the BLDC-Motors its mostly multi strand wire.
Thank you
Thank you
