Pressurize acrylic cylinder dinamically
Posted: Jun 22nd, 2020, 6:03 pm
I just realized that the problem of objects imploding underwater is the difference in pressure. If I could measure water pressure outside the rov and air pressure inside the rov I could make a system that with a gas can it pressurizes the cylinder, then when going up I could put a valve or a pump that would get some air out depressurizing the cylinder.
Do you think this is a good solution to make it possible to go deeper with the ROV? Did you try it?![Fishy <><](./images/smilies/icon_fishy.gif)
