ROV Nudibranch sea water test
Posted: Feb 17th, 2019, 5:08 am
This is the third test in sea water and has worked the best so far, the first two weren't worth editing footage. After the second test I needed to add more lead to get neutral buoyancy, actually connect the power for the camera to the LP FPV filter so the feed doesn't drop out when the motors are running and add a trim tab to the back to make the ROV stay level when going forwards.
Now I need to get out in the boat and get some good footage.
https://youtu.be/BCTs1w8no_I
