Difference between right and left hand propellers ?
Posted: Oct 17th, 2015, 9:25 pm
by vik
Hello, is there any major difference between left hand propellers and right hand propellers, and how can this affect the ROV ? Is it also correct, that having a propeller and rotating it one direction will make the ROV rise up,and rotating it the other direction, will make the ROV go down. And this applies if the thruster is for upward аnd downward motion. Doеs this have anyтhing to do with right or left hand propellers ?
Re: Difference between right and left hand propellers ?
Posted: Oct 18th, 2015, 8:26 am
by kenl
Good question!
Especially with regards to the up and down influence, I've read with boats it affects the left and right, but with smaller boats it is so subtle that it is not a major factor, I don't know much about ships and larger boats.
I guess if you can balance things out then why not but at the end of the day the drag from your tether will be more of an influence than most other things
Posted: Oct 18th, 2015, 9:12 am
by vik
Thank You for the reply. The plan for my ROV is 50cm long, by 35cm wide and 35cm high. These are rough estimates as of now. Therefore the orientation of the propellers will not make a difference, due to the size of the vehicle ? So I can go with either left or right hand propellers ? Thanks for the reply once again, it clarified a lot of things to me.
