Laser Cut Frame, Camera Housing ROV Project
Posted: Apr 17th, 2015, 11:31 am
I have been wanting to work on ROV for a while, but have been very busy with work, now finally got some spare time to work on some ideas.
I design camera mounts, pods for FPV planes, custom ground stations and I also fly multi rotors so I wanted to have the steady multi rotor control on my ROV too. From all the designs I have seen (3,4,5,6 thrusters) I went with what the expensive commercial ROV's are using for my first project..... 6 Thrusters design
Thrusters = I decided to go with (6) Turingy 28mm 750kv brushless motors with some Traxxas Villain 44mm propellers (right and left rotation props), I plan to switch the metal bearings to custom teflon or delrin bushings, change screws to stainless steel and so on, some epoxy waterproofing to some internals will be made too. (motors will be easy to replace if they get damaged)....this is until I find better motors.
ROV Battery = (2-3) 3S 5200mAh Lipo batteries
ESC's = I will be using some hobby king boat 30amp (forward/reverse) brushless ESC's.
ROV Control= I might go with a PPM signal from my RC radio to the ROV, to control all the ESC's and RC switches etc. less wires.
Video = will consist on 4 Cameras, (1) GoPro Hero 4 and (3) Sony 700TVL Cameras (with the option of mechanically removing the IR filters for better low light) always providing live video feed to the surface DVR. (Front, Bottom, Back)......The GoPro and Front 700TVL camera will be mounted on a 2-Axis Brushless Gimbal, with Tilt control.....A Remzibi OSD will be added on the front camera to show direction, depth, battery power, temp, and any other sensor I can add to it.
Ground Station = Pelican style case, 19" Widescreen LCD or 12" Sun-readable monitor, 4ch SSD DVR, custom 9ch radio controller, 19Ah SLA battery.
I have many other parts to add as I go, I'm still deciding what dome/tube combo to buy or built, what tether cable I should use, but I will put my progress as I go.
So far here are some pictures of the frame I'm making (Laser cut high impact ABS) motors and propellers are not the ones I will be using, but you get the idea on how it would look like. The ground station monitor and case is the one I will be using but with a different bottom plate.
I will post more pictures as I go, any input will be appreciated too.
