Hi folks,
I upgrading my ROV doing mods on the bilge pumps, using relays and an usb interface for control. I understand the main supply is 16 gauge wire seperate to the control wires but still part of the tether as a whole. Is the common positive better being directly wired to positive supply if not where does the common supply come from also does the main positive, negative 12v dc supply come directly from the battery or is somehow done through the usb interface control box.
Power suppl
Jump to
- Still on the Dock - Newcomers & Site Support
- ↳ **** READ THIS BEFORE TRYING TO JOIN **** **** READ THIS BEFORE TRYING TO JOIN ****
- ↳ Board Messages
- ↳ Forum Help & How To's
- ↳ Tests
- ↳ Introductions
- ↳ Get Your Feet Wet
- In the Shop
- ↳ Your Workshops
- ↳ The Tool Room
- The Drawing Board
- ↳ Computer Aided Design
- On the Bench - Pieces and Parts
- ↳ Control Systems and Tethers
- ↳ Frames, Hulls, & Bouyancy
- ↳ Thrusters
- ↳ Cameras
- ↳ Lighting
- ↳ Manipulators & Tools
- ↳ Electronics
- ↳ Miscellaneous
- The Code Room - Programing
- ↳ Arduino
- ↳ Raspberry PI
- ↳ Miscellaneous Programing
- In the Water
- ↳ Your ROV Projects
- ↳ AUV's
- ↳ Mission Footage
- Back on Shore
- ↳ The Mission is Over
