I made a boo boo with my ESC
Posted: May 12th, 2014, 11:48 am
by Erik102696
I was stupid and I didn't put electrical tape around the alligator clip attaching the battery pack to the ESC so when I set it down the two touching and made a huge spark. Im guessing its fried. When I try and control my motor it just chatters and won't start. Does this mean that it is fried?
Re: I made a boo boo with my ESC
Posted: May 12th, 2014, 6:43 pm
by kenl
I don't think that would have fried your ESC, might not have done your battery much good.
What are you controlling the motor with, a servo tester? Is this the first time you've run it or was it going before?
Posted: May 13th, 2014, 11:57 am
by Erik102696
I'm useing an arduino and a usb shield to controll it with a ps4 controller. It was working before. Right after the leads touched the motor worked. Now it's chattering. I went to charge the battery and it said it was fully charged so I don't know if it is a battery issue or what it is.
Posted: May 13th, 2014, 7:06 pm
by kenl
It's a bit hard to say, do you have an alternative power supply to try, even a car battery?
Can you cycle your battery on your charger? In other words dis charge and recharge?
Posted: May 13th, 2014, 8:04 pm
by Erik102696
i tried hooking it up to a car battery. it went and spun a little then started chattering again.
Posted: May 13th, 2014, 8:55 pm
by kenl
Um the only other thing I would suggest is trying to reprogram the ESC if that option is available.
Posted: May 14th, 2014, 10:34 am
by Erik102696
This is the ESC
https://www.hobbyking.com/hobbyking/sto ... verse.html
It is possible to program the ESC but I don't know what part of it I should program. Do you think you could help me out with that?
Posted: May 14th, 2014, 2:35 pm
by scubersteve
did you buy the program card?
Posted: May 14th, 2014, 7:51 pm
by kenl
Hi Erik,
I have the same ESC, i use a program card but it can be done manually using the little white button on it and I think it may need to be connected to a radio and Rx. Check the manual it is available under the files tab on that link.
In the mean time if it were me I would also order a program card for the Hobbyking ESC, and probably a similar ESC, just in case yours is Kaput.
Posted: May 15th, 2014, 8:07 am
by Erik102696
I did order another ESC but it seems that these ones are in really high demand because they are always on back order
! But I will look into programing it and let you know what I find.
