Welding PVC pipe?
Posted: Dec 9th, 2013, 8:35 am
by Dace
I was perusing Harbor Freight tools this morning and stumbled across a plastic welding iron. This gave me an idea so I googled "welding PVC pipe" and apparently it can be done using special rods which HF does sell. I was wondering if anyone has done this and how well did it work. The iron I was looking at gets to about 1000* which I would think is the minimum you would need to melt PVC. Its $70 and comes with 3 tips and has a built in air compressor. This would open up a lot of possibilities and remove some of the limits at which you could design and build an ROV.
Re: Welding PVC pipe?
Posted: Dec 10th, 2013, 5:41 pm
by Dace
Ok, the lack of responses tells me it may be a, not so good idea. But thats ok, I think I will try it anyway. I'll post my findings, fails or hopefully successes. : )
Dace
Posted: Dec 10th, 2013, 6:46 pm
by kenl
Hi Dace,
I have bought a hot air PVC welder on ebay, I think there is a bit of learning involved in getting a good looking weld. My meager tests so far have been, well OK.
Tight fitting, primed joints and glue provide as strong a joint in my opinion. In my case I'm using both.
I have just about finished my hull and will in the next few days start a new thread on my ROV it will show some my welding attempts.
Try viewing some of the YouTube tutorials on PVC welding.
Ken
Posted: Dec 11th, 2013, 6:43 am
by Dace
Hi Kenl
Thanks for the input. I have been watching youtube vids on using the welder. I do have experience in welding steels either with a stick, mig or gas, plastic is another medium that I have never done so I'm sure there is a learning curve. My design calls for short adapters afixed to the sides of the hull which will also be afixed to the thrusters which kind of look like out riggers. I don't want to use screws which would penetrate the hull and would be more points for leakage. Welding the adapters to the hull is less intrusive. I'm working on a drawing in Sketchup and will post it so you get the idea. I look forward to seeing your design. Thanks again Kenl.
Dace
Posted: Dec 11th, 2013, 11:31 am
by a_shorething
Dace,
If you're using standard sized PVC pipe I may have a solution for you. I'm working on a set of 3D printed standard sized brackets that would go around PVC of standard diameter and give a point to 'bolt' them together without penetrating the hull.
This would make PVC pipe into a kind of 'erector set' to be altered and attached as needed without having to glue everything in place or come up with other creative solutions.
Stay tuned....
Posted: Dec 11th, 2013, 2:17 pm
by Dace
Sounds interesting. I'm always looking for new ideas. Thanks
Dace
