kenl wrote:the pool cleaner wire didn't excite me too much due to it's price and only having two wires
Yeah, same here, which is why I kept looking for alternatives. The pool cleaner cable is 1) too expensive 2) too weak 3) too thick 4) too buoyant. While I thought it was interesting at first I now consider it a non-starter.
I never liked the idea of strapping floats to the cable either. But there is just no way around it; you
have to have a cable (unless you go fibre optic), it
has to have some buoyancy, and
ideally be strong enough to retrieve the ROV with in case of a malfunction.
Something must provide that buoyancy! Once I accepted that I was only a quick web-search away from an abundance of options!
kenl wrote:I think if you could get it in 20m lengths threading it on to a cable would be possible if laid out in a straight line, first you would pull a string through it with vacuum cleaner then pull your cable through with that
I have a slightly different idea: I think if you lubricate the cable with something (ummm... how about silicone!) and attach a firm "needle" object to one end, say a foot or so of some thin metal rod with a rounded tip, I reckon you can thread it through with a little effort. Since the foam tube will have some elasticity it will open up when you push it over the "needle" and you can probably push waves of expanded tubing along the cable. Of course this means it will take longer and longer time as you progress (since you'll have to push each "wave" all the way to the end of an ever longer piece of tube) but with patience and a bit of elbow grease I think it could be done! How much elbow grease depends on how tightly the cable fits - by leaving a little extra room the job should be easier.
kenl wrote:it would take a few helpers though.
Help is always good - unfortunately also in very short supply here! If it's going to be done I'll have to do it myself.
kenl wrote:The only down side may be compression of the foam at depth and the resultant loss of floatation.
Yep, but I think we'll just have to live with that. In fact it may even be a good thing as the cable will become increasingly buoyant as it reaches towards the surface, it's possible this will keep it at a sloping angle which should help avoid entanglement. Maybe this effect should be taken into account, by dimensioning the foam tube so that the cable is ever so slightly positively buoyant at surface pressure?
I'm always open to suggestions though, so if anyone can think of an alternative...
