Mag coupling version 3.0 vid (updated new video 1/25/15)
Posted: Nov 17th, 2013, 7:55 pm
Making progress on my magnetic coupler idea.
Here was version 1.0: the proof of concept:
And here is today's test (version 2.0):
It uses an 1100 gph bilge pump motor, some 3D printed parts and fits inside 1.5" sched. 40 PVC. My motor controller is just an Arduino shield for testing and I already cooked 1 of them so I haven't cranked it up to full power yet, but I am sending it almost half power and it seems to have pretty good torque. The motor doesn't seem to heat up at all (mostly because the board is the weakest link I assume). I'm just sending 3-4 vdc at less than 1 amp so far, but it's working!
I plan to play with the size, pitch, and number of prop blades in order to find the best option. Once it's done, the plan is to have a completely self-contained and sealed thruster design that you can pretty much just attach to your frame wherever you like.
Total cost for the sealed unit: under $50.
My plan is to build a test stand and see what kind of numbers it's putting out and compare different configurations of thruster blade.
It's coming along nicely though...
What do you think?
What do you think?
