Mgbss wrote:Looking like an "A" so far
Did you run the wires for the motors and other exterior features under the fiberglass? How are you sealing the back of your PVC ? What Channel MHz are you running on your 6 channel radio?
Please post more info looks like a very cool build
Joe
thank you! I ran the wires behind the "wings" its open to the water and not covered like the front, that way water can enter and counteract the hydrostatic forces at depth. therefor only the middle pvc pipe will experience pressure. This also allows me to be able to unplug and swap out a motor if needed.
the back of the PVC is a threaded cap, where I just apply a little bit of Teflon tape and screw in the cap.
im not too sure on the MHz of the radio, its just one I picked up form a friend who flies rc planes
here I attached a picture of the "business end" so you can see what I mean.
hopefully I can put it in a pool this weekend and post some pics
<a href="
http://s9.photobucket.com/user/deadoral ... 1.jpg.html" target="_blank"><img src="
http://i9.photobucket.com/albums/a72/de ... /rov-1.jpg" border="0" alt=" photo rov-1.jpg"/></a>
