Voltage Drop Board
Posted: Sep 18th, 2013, 5:13 pm
Here is my voltage drop board. When the 12v+ gets to the ROV, its dropped down on this board to 9v and 6v respectively. The 9 volts goes to power the Ardunio and the 6 volts goes to power the servos. I wanted less wires running back and forth, so this was my solution. Looks horrible but this is a prototype, and it works, and will use it until I can make a fancy one. The heat sink is over kill, I need to cut it down a bit to fit inside the hull. All the connections will goto a protoshield for the Ardunio. I'm making a lightboard to sit on bottom of this one to take care of the lighting wiring.
