Brushless Thruster-Unit
Posted: Sep 10th, 2013, 4:46 am
by ROVER3D
Here you can see my easy-to-build Thuster-units using brushless-motor. There are two 45mm 3-blade propellers each side. With housing you will get a very good speed and protection.
I'm using this units for years....
Re: Brushless Thruster-Unit
Posted: Sep 11th, 2013, 8:27 pm
by Rover
Thanks for sharing. Looks like a great design. Have you ever conducted any thrust tests. If so, I am curious about the thrust and current draw you see.
Rover
Posted: Sep 12th, 2013, 1:00 pm
by ROVER3D
Sorry, haven't tested it yet. But for my application it works fine. At full speed running at 9A. Because of the two propellers there is more security at operation. At a dive one prop breaks but the unit works until the ROV come back to surface.
Posted: Sep 25th, 2013, 11:32 pm
I like that concept! are both props the same? (right hand vs left hand)
Posted: Sep 26th, 2013, 2:32 pm
by ROVER3D
Yeah good question. I had the same question but if you think about it you will get the right answer ;-). One thing: when the motor turns one prop thrust forward and one backwards :-)
*they have to be the same. if you use two units take one left hand and one right hand to neutralize rotating movement.
i recommend sealing the motor with epoxy: (german link)
http://www.r-o-v.net/viewtopic.php?f=17&t=414
Posted: Oct 9th, 2013, 2:38 am
by Lost Bob
Did those motors come with a long enough shaft or did you install a longer one ?
What are those motors ? Looking for 750 Kv range.
I have a similar idea for my lateral thrusters.
Thanks Bob
