Bouyancy Problems
Posted: Aug 31st, 2013, 12:20 am
Ok.... so. When I originally started my own custom ROV, I took note of some issues a SEAPERCH kit had. At a certain depth, the ROV would sink and the motors were not powerful enough to bring the ROV back to the surface. It used simple foam tubes for buoyancy. I judged that under pressure the motors could not bring the ROV up. While this is true, it is because the pressure was squeezing air out of the foam - which I just realized. On my new ROV I plan to use some PVC pipe sealed with air. When I originally tested my ROV, without the air for buoyancy, my vertical motors could not bring the ROV to the surface at 5 feet down. When I put the sealed pipe with air in it on, will my motors be able to better maneuver my ROV vertically? Even at a depth of 100 feet? I know it will change where the ROV is buoyant at, but will it help my motors get my ROV all the way to the surface?
