controlling the ROV
Posted: Aug 3rd, 2013, 8:29 am
by Under_The_Surface
hey all
I was wondering if someone could tell me if its better to use relays to control the ROV with 1 common power wire or Monetary switches with separate leads running down the tether?
Much Appreciated
Re: controlling the ROV
Posted: Aug 3rd, 2013, 9:56 am
A good general rule, the smaller the tether, the better. A smaller tether creates less drag, allowing you to be more agile in the water, as well as allowing your ROV to get the best power ratio out of your thrusters. So the fewer wires in your tether, the better.
Posted: Aug 3rd, 2013, 11:06 am
by ERIEWRECKDIVER
So far I have been successful with relays running my thrusters and lights. I run all of this off of one 12/2 power cord from the surface down to my relay box on board the ROV.
I control the relays via CAT6E control cable. So the 12/2, CAT6E and the Video Cable make for a lightweight and fairly flexible tether.
Best of luck.
ERIEWRECKDIVER
Posted: Aug 4th, 2013, 3:24 am
Thanks guys for your responses
I think if I can ill get my hands on some relays
it sounds like the best option
thanks again,
Under_The_Surface
