Hello, I'm building my 2nd rov and want to use and arduino I will be controlling 3 thrusters,a servo( for camera tilt),lights and 2 lasers and will be controlling every thing with a ps2 controller or a control panel with a 2 axis joystick. What will I need to make this work?
Thanks in advance!
Re: Arduino for control?
Posted: Jul 20th, 2013, 1:37 am
by njs552
Hi there!
I am currently working on a control system of a similar design, minus the lasers
Here is a video I made describing my control setup:
I just finished testing my brushless thrusters, and have added and LCD screen to my surface control, and a Arduino controlled Heads up Display video overlay to my video feed. I also made a custom Printed Circuit Board to make connections in the ROV easier.
Here is what you would need to make a similar PS2 Controlled system:
Surface:
-Arduino Uno/Mega/etc
-PS2 Controller
-MAX488E Serial Converter
In ROV:
-Arduino Uno/etc
-MAX488E
-1-4 relays depending on if you want to control your lights/lasers together, in groups, or individually.
