Lighting at 30m
Posted: Jun 9th, 2013, 11:48 am
by ROVEnthusiast
I am building my first deep diving rov and I am not sure how powerful my lights need to be or if they should be halogen/LED. I am expecting to go to about 30m and the water has 10-15 foot visibility, so I am looking for options. Also, I have a tight budget so preferably something under $30. Any ideas/suggestions?
Re: Lighting at 30m
Posted: Jun 9th, 2013, 4:37 pm
Hi ROVenthusiast. Unless someone else on the forum has experience with distance, camera type and lamp type, I would suggest trying out something like this
http://www.jaycar.com.au/productView.as ... rm=KEYWORD . There is a data sheet on the page and you will see the current draw is very small compared to halogen. Depending on where you are, you should be able to find similar locally or certainly online.
Much easier to implement than halogen too. Just solder on the wires, blob some epoxy on and you're set to go. As for where to position the lights, see how the divers do it for their photography
Ross
Re: Lighting at 30m
Posted: Jun 10th, 2013, 12:22 am
by ROVEnthusiast
Thanks, I'll look into that!!!
Re: Lighting at 30m
Posted: Jun 10th, 2013, 6:29 pm
Hey Ross,
I do like the look of that LED module! Much easier to throw into a system then a high power LED that requires a special driver! I might just have to investigate this part a bit further!
Re: Lighting at 30m
Posted: Jun 10th, 2013, 6:48 pm
No worries. Don't know how good they are but at $10 worth playing with I recon.
Re: Lighting at 30m
Posted: Jun 11th, 2013, 11:02 pm
by ROVEnthusiast
Only prob is that they are currently out of stock...
Re: Lighting at 30m
Posted: Jun 16th, 2013, 11:52 pm
by ROVEnthusiast
What do you think about a laser?
Re: Lighting at 30m
Posted: Jun 16th, 2013, 11:54 pm
by ROVEnthusiast
(Explained on my IR laser post)
Re: Lighting at 30m
Posted: Jun 24th, 2013, 5:19 am
by fryslan76
I have seen numerous post, on a divers forum for building lamps, about CREE LED boards which have included driver boards. If you add a mirror to shape the beam it will work as a charm. And some of them dive a lot deeper than 30 meters.
