Two camera questions
Posted: Jun 6th, 2013, 12:40 pm
I have a gopro as my main camera with a simple yellow RCA feed running up my tether. I also have a second IR camera I wasn't planing on using, with the same yellow RCA output. My tether has a single unused wire left in it. So here's my first question: each RCA is made up of two wires, can I wire one of these two wires as a common for both cameras and use my free tether wire for the second camera? That way I can switch between either cam on the controls.
Second question: if I do use a second camera, where is a good spot? My primary camera is forward facing and tilt-able. So guys with a second cam, where do you like to face them?
