tether wiring
Posted: May 25th, 2013, 5:49 pm
by jonnyhas
Hi guys n girls, my new tether has 3x 18 awg wires and am using 2 no dc-dc step up converter's to up t he voltage they are rated 15a so was going to hook them up in parallel will this work? And also should use 2 no wires for each + and single for ground? Will this make a difference or will it not really matter?
Any help greatly appreciated
Cheers
Jonny
Re: tether wiring
Posted: May 26th, 2013, 5:11 pm
Hi Jonnyhas. The question is a bit unclear. Could you explain better or put up a diagram?
Re: tether wiring
Posted: May 27th, 2013, 10:58 am
by jonnyhas
Ross, I have purchased a per manufactured cable that has 3no 18awg cores I am really wondering if I use 2cores for the + and the remaining core for the -/ground will this be better or make no difference than just using one core for + and one core for - ?
Hope that's clearer :? :D
Cheers jonny
Re: tether wiring
Posted: May 27th, 2013, 4:26 pm
Thanks Jonny. Using one conductor for supply and one for ground would have more voltage drop than 2 for supply and 1 ground. So for a given length of cable and given total current you would drop say 4 volts for the 2 wire versus 3 volts for the 3 wire. Usually, the bigger wire and hence less voltage drop is desired for ground because ground is conventionally used as a reference. So use the 2 wires for ground and the third for supply. That way you will have less problems if you add control wires later.
Re: tether wiring
Posted: May 28th, 2013, 8:58 am
by jonnyhas
thanks Ross, i wont have any more for control as i am using a vellemen 10 channel kit, although i do have a single control relay for switching the light's on.
cheers jonny
