Triangle frame
Posted: Apr 23rd, 2013, 10:58 am
by Aphire
So i did my first test of the rov and it seems it likes to fly upside down... i cant figure out where to put my weights, can anyone point me in the right direction?
Re: Triangle frame
Posted: Apr 23rd, 2013, 11:41 am
Generally speaking, you want the weights as low as possible on the frame and the flotation as high as possible on the frame. This will give you the best stability on the surface and in the water.
Horizontally, the flotation and the weight should be "stacked."
The center of your weight should be below and in line with the center of your flotation.
For a quick test, you can try tying weight to the bottom of your ROV, suspending the weight from the bottom "pulls" the ROV to the correct positon.
