Greetings from a newbie in Michigan
Posted: Apr 4th, 2013, 2:48 pm
Greetings from a newbie in Southwest Michigan. I hope to build a video ROV for shipwreck documentation and searching here in Southwest Michigan. I have been looking at the "Open ROV" but thought I would see what other ideas are out there before I bought the kit. I want to document some wrecks that have been recently located in the 250-300 foot range, and would like to use surface supplied power in a compact unit. Lighting will be my greatest power draw as natural light at that depth is an issue. I also think I want to be able to move side to side so I can swim up to the wreck and keep the camera at the same angle and move the ROV around the wreck.
I notice that most ROVs do not have tilt, but seem to remain level when floating and only some have lateral thrusters.. What are the pros and cons of adding the extra thrusters to do this? I am thinking I can control the standard Forward/Back - Left turn/Right turn on one joystick and the tilt up/tilt down - Left Lateral/Right Lateral on another joy stick. Thoughts and comments?
