First rov design
Posted: Mar 28th, 2013, 11:46 am
So i think ive gotten down to finding what parts i need thanks to this awesome forum!! you guys are awesome!
Im using pvc pipe for the frame (pic below) its not glued together nor have i put all the main components on but it gives me an idea of how im going to place items.
I think ill be using i basic Cat5 tether which then connects to the motors directly and plugs into a homemade controller. ill be using a camera which i hope to pan back and forth and also move up and down. the only thing im not sure about is what ill be using for thrusters. Ive seen that people have tried boat blowers, but i want to see if theres a way to water proof them. If not, ill probably be using a normal bilge pump.
list of parts:
PVC pipe (X)
Hull/bigger PVC
Relays (X)
LED lights ()
Cat5 cable ()
Controller box ()
Center off switches ()
ON/OFF switches ()
Ethernet in port ()
camera (X)
Camera servos (maybe...)
Floats and weights ()
Extra wires (X)
Wire connectors ()
Thrusters ()
Dome for hull ()
Any suggestions or questions are welcome! thanks for the help everyone!!
list of parts:
PVC pipe (X)
Hull/bigger PVC
Relays (X)
LED lights ()
Cat5 cable ()
Controller box ()
ON/OFF switches ()
Ethernet in port ()
camera (X)
Extra wires (X)
Wire connectors ()
Thrusters ()
Dome for hull ()
