Boat Blower thrusters?
Posted: Mar 26th, 2013, 10:49 pm
by Aphire
i saw this thread from a while back, i was wondering if there was a way to make them water tight?
Re: Boat Blower thrusters?
Posted: Aug 30th, 2013, 12:46 am
by Rover
Boat blowers are somewhat airtight, Designed to keep any flammable fumes away from the arcing of the motor brushes, but are not specifically designed to be water tight at depth.
Even with that said, you may want to run one submerged, the motors will run underwater totally wet. With the extra drag of the water the impeller is moving, how may amps would the motor draw, and is it over loading the rated motor amp draw. Water has a lot more resistance to flow then air does.
Let us know how your testing goes.
Rover
Posted: Aug 31st, 2013, 8:39 am
by DavidF
ive played with a 4" attwood blower, it works but draws way too many amps.
http://www.youtube.com/watch?v=tP50ajpb ... ahmmmYbb2A
Posted: Sep 4th, 2013, 10:10 pm
by merbass
How much did they draw in your tests?
Posted: Sep 4th, 2013, 10:34 pm
by DavidF
Pegged a 20 amp meter, best I can tell ya.
