I've been looking for a suitable sized perspex dome since I started this build about 5 years ago and one finally came up on e-bay from a company called "project plastics".
70mm dome diameter, 3mm thick and has a 10mm flange, sounded perfect and at only £7.50 it had to be worth a try.
It arrived today so I've been having a play with it.
It's not optically perfect but at that price I'm not surprised and it doesn't show up much once you're under water.
I had to add 250g of ballast to overcome the dome's bouyancy (8 M12 stainless nuts) so the extra drag of the ballast might over-rule the reduced drag from using the dome, we'll see on sunday. also see below.
Of course, with the flat face plate I could mask the ring of led lights from reflecting off the perspex and back into the camera, I can't do this with the dome so the lights are useless but the camera has excellent low light specs and at the depths i go to i don't need them anyway.
Depth rating wise, a similar camera dome port 3.5" diameter and 3.8mm thick is rated to 750m with a 2:1 safety factor so I think I'm totally safe down to a couple of hundred metres or more and I don't go anywhere near that.
I also found someone selling 3.5" pump gaskets so I got a couple to try, they're quite thick at 4mm but I kept having to replace my old ones every time I opened the pressure hull as they were soft neoprene. These are much stronger and seem good.
Thinking about drag....
drag coeficient of flat plate = 1.17
drag coeficient of solid hemisphere = 0.42
Ok so there's more to it than that because of the shape of the hull, bouyancy, thrusters etc but you get the idea.
