Page 5 of 13
Re: Raspberry PI based ROV
Posted: Feb 15th, 2015, 11:27 pm
by Moki
perfo wrote:Now when I run it :-
Code: Select all
root@ROV:~/Moki-ROV# node server.js
PCA9685 Not found, disabled!
MPU9150 Not found, disabled!
MS5803 Not found, disabled!
MCP3424 Not found, disabled!
ROV Server up and running. Go to http://192.168.2.13:3000
Fair enough it can't see the various I2C board as I haven't got any connected....
It runs for about 10 seconds then
Code: Select all
connected
/root/Moki-ROV/server.js:412
imuserver.on('listening', function () {
TypeError: Cannot call method 'on' of undefined
    at Namespace.<anonymous> (/root/Moki-ROV/server.js:412:11)
    at Namespace.EventEmitter.emit (events.js:95:17)
    at Namespace.emit (/root/Moki-ROV/node_modules/socket.io/lib/namespace.js:205:10)
    at /root/Moki-ROV/node_modules/socket.io/lib/namespace.js:172:14
    at process._tickCallback (node.js:415:13)
Do I have to run this as ROOT ie sudo su - or should it run from a normal user ? Not a problem as long as I know...
Sorry for so many questions. It does look good even though its only for 10 seconds :)
As it was designed to be an embedded system, there was never need to run it as non-root. Just run it as root.
Ofcourse, if you wish to run it as non-root. You have to change a few things.. ill just add that to the wishlist.
As you don't have a MPU-9150, the software doesn't init the MPU-9150 routine... which breaks the code later on in the program. Ill see if i can add another if-then construct to fix this.
Posted: Feb 15th, 2015, 11:29 pm
by Moki
perfo wrote:hmmm
I have to use
sudo modprobe i2c-dev
to get my I2C running but once I've entered that is appears to be ok....
Just add "i2c-dev" to your /etc/modules file. That should fix that.
Posted: Feb 16th, 2015, 12:30 am
by Moki
Released version 0.1.1
- It should fix the sensor errors :)
- And will show "N/A" on the webbrowser page, if the sensor was not detected.
- Volts should work.
- Fixed a few typos :?
- No need to edit the ip adress in the server.js program... only edit the files in the public directory.
Posted: Feb 16th, 2015, 12:51 am
by perfo
Splendid, do I need to do the full install again or can I just update bits of it to pull in the new server.js ?
Posted: Feb 16th, 2015, 3:24 am
by Moki
I would recommend, a fresh install...
That way it is easier to debug any problems you may encounter.
Posted: Feb 16th, 2015, 9:33 pm
by perfo
Yep all works great now...thanks..
when you type in
Code: Select all
node server.js
You get the message all is good but it tell you to got to address 0.0.0.0:3000 rather than the Ip address of the raspberry pi which I think it used to do.. Anyway this doesn't really matter as long as you know the actual address. As pointing the browser to the actual ip address brings up the page in it's splendour. My webcam picture is too big and not in the right place though...
Anyway that has given me enough to play with I'll see if I can decipher what's going on and go from there...
Thanks for your help...
Posted: Feb 16th, 2015, 11:57 pm
by Moki
The ip 0.0.0.0 is special, it means it listens on all network interfaces.
Posted: Feb 18th, 2015, 6:08 am
by perfo
yep,, it was handy though if you didn't know the ip addy of your pi. I haven't got mine set up as a static IP so it does change from time to time..it's easy enough to make it static I just keep changing the software around and not getting around to it... Thanks
I'm actually thinking it maybe an option to have two markers on the heading and depth scales. One for actual and one for demand. Thus don't control the motors directly but rather set a demand value using the joy stick and let the controller and heading feed back, guide you in.. maybe even a PDI controller? Same for depth.. Just a thought...
Posted: Feb 18th, 2015, 12:10 pm
by Moki
Yes, controle by wire would be great... the water current moves your ROV, and it adjust itself, to keep steady.
I'll just add it to the wish-list ;)
Not sure, what a DPI controller is... didnt google. Is it, force feedback?
Just so you know, there is already some "hover"ing already in the control program.
Posted: Feb 18th, 2015, 3:46 pm
by perfo
ha I called it PDI and you called it DPI and it is actually a PID three term controller. its no wonder I confuse people. It's done in maths and alters motor speed depending on how far out the desired is from the actual and constantly adjusts as you close in to prevent over shoot.
