Page 3 of 3
Re: New controller board discussion
Posted: Nov 28th, 2011, 10:17 am
by derelicte
chriskon149 wrote:Also, two Arduinos should be able to communicate over UDP using Ethernet shields, if that is what you're interested in, without the need for a computer in between them. That should (correct me if I'm wrong) let you use a longer tether than serial.
Chris K
sort of. differential serial (rs-422/485) can operate up to 1200m. ethernet's twisted pair limit is 100m. rs-232's practical limit is probably around 50' or so.
however for the lengths we are talking about for our purposes (say 100 - 300'), either interface is fine. but serial is far simpler and less expensive.
Posted: Dec 7th, 2011, 9:16 pm
by chriskon149
Ahhhh. Thank you for those specs. I haven't worked much with serial on the Arduino platform (other than for debugging outputs). I've used mainly UDP for communication, so I'm most familiar with that.
Thanks for the information!
Chris K
