Re: Bot Cousteau- My ROV project
Posted: Jan 19th, 2015, 10:12 pm
OK, got the new prop printed (6 blade) and it's giving a little more thrust at about the same draw. This one was up to 123 grams of thrust at about 1.32 amps of draw.
Also, switched to a 30 gallon tub instead of the one I was using (about 5-8 gallons I guess). I was worried that the small tub was setting up currents that were messing with my readings. This one looks like it's got less turbulence and I'm thinking, more like an actual dive environment.
Still not sure if longer prop blades or more blades will give me more thrust.
Tomorrow I plan to print an 8 blade prop out with all other dimensions remaining the same and see how that goes.
So far, not really drawing much in the way of total power, but just by eyeballing it and feeling how much thrust is coming from it, I'm thinking it's close to enough to move a small ROV around pretty well. If that's the case then there will be an option for powering a small one without having to expose the motor to the sea!
More to come...
PS- I shot some video but the frame rate of the camera is just about synchonized with the prop speed so it looks like the prop is slowly moving backward! It's like when you see a car in a movie with wire wheels going slowly and they look like they're spinning in reverse. It just looked strange.
More to come...
