Page 3 of 3
Re: New ROV design/build *JaxExplorer1*
Posted: Dec 18th, 2013, 7:24 pm
by fireslayer26
Zaibach wrote:Looking cool
Definitely interested in seeing how the X³ handles. Also the Linear actuator is waterproof or are you modifying one and how much did the X³ and actuator(s) run if you don't mind my asking?
The actuator will be sealed. Only the small metal rod from the gripper will be coming through the case for the actuator. This is the area I will have to seal, but still allow it to move back and forth. Maybe a separate small grease filled compartment.
I haven't received the X3 board yet. I will be doing beta testing for the creator when it arrives.
Posted: Dec 18th, 2013, 9:07 pm
by fireslayer26
Here you can see the motor and light wires feeding into the main hull.
Posted: Dec 19th, 2013, 6:18 am
by Oldsirhippy
@fireslayer26
Thanks for the information.
I have a calculator to work out how much pressure a flat piece of acrylic of a certain diameter can withstand. But am unsure whether the dome would withstand higher or lower pressures than a flat disk.
Do you know how to calculate the pressure a dome of x" diameter, y" thick and z" high can withstand?
Posted: Dec 19th, 2013, 1:54 pm
by fireslayer26
I think that domes are stronger. Though I'm no expert on the topic. But I think the depths that most of us go to, a flat disk of a decent thickness would be fine. Maybe someone else here can offer a more educated opinion though.
Posted: Jan 2nd, 2014, 7:18 pm
by fireslayer26
Newest pics
Dome installed
Wiring cleaned up
Internals
All sealed up
Posted: Jul 7th, 2014, 8:11 pm
by fireslayer26
Just got my new test boards courtesy of ROV-Control. Can't wait to test them out!!
Posted: Jul 8th, 2014, 12:54 am
by Bubbles
To calculate pressure use the free program (under pressure) at
http://www.deepsea.com
It will defenately help you!
What is your opinion about rov-control?
