KR2 ROV
Re: KR2 ROV
WOW!!! That is going to be awsome!! Let me know when you get the code cleaned up, I would love to go this route on my rov.
- bikerbones1968
Re: KR2 ROV
Looking good KR2. Every successfull step is a step forward.
Re: KR2 ROV
Question, when all is said and done will you be communicating from one arduino to another via Ethernet or some other means?
Re: KR2 ROV
Hey David,
Yes... that is the plan. At the moment I am thinking of an Arduino Mega in the Sub and a Uno at the surface. I think I am going to use RS485 coms to communicate between the two units... cheaper (and smaller) then the Ethernet shields!
I am off to Germany for the week on business, but I hope to clean the code up next weekend, and when I do, I will post it here.
Cheers!
Ryan
"KR2_Diving"
Cheers!
Ryan
"KR2_Diving"
Re: KR2 ROV
That would be great. I have the arduino's sitting here and just ordered 2 ps2 controllers today.
Re: KR2 ROV
Hey David,DavidF wrote:That would be great. I have the arduino's sitting here and just ordered 2 ps2 controllers today.
Recommend getting an extension cable as well. Using this as the hard wired connection will allow you to easily swap out a controller, pack your system, and just be less of a hassle in general. They are cheap on amazon.
Re: KR2 ROV
KR2_Diving wrote:Hey David,DavidF wrote:That would be great. I have the arduino's sitting here and just ordered 2 ps2 controllers today.
I was just going to splice in a db9 connector. Thought it might be better as I can bolt the connector to the case. Unless there is something I'm missing.....?????
Re: KR2 ROV
My only thought would be... lets say your controller packs it in and dies, or gets dropped over bored... if you made your db9 connection on the extension cable, you can plug a new PS2 controller in right out of the box.DavidF wrote:I was just going to splice in a db9 connector. Thought it might be better as I can bolt the connector to the case. Unless there is something I'm missing.....?????
I will be using a D-Sub connector myself to actually hard wire the controller in, VIA the extension cable.
Re: KR2 ROV
Code is cleaned and posted over in the Control Section!
viewtopic.php?f=15&t=831
Best of luck!
Ryan "KR2_Diving"
Best of luck!
Ryan "KR2_Diving"
Re: KR2 ROV
KR2_Diving wrote:My only thought would be... lets say your controller packs it in and dies, or gets dropped over bored... if you made your db9 connection on the extension cable, you can plug a new PS2 controller in right out of the box.DavidF wrote:I was just going to splice in a db9 connector. Thought it might be better as I can bolt the connector to the case. Unless there is something I'm missing.....?????
Yea that makes more sense, ill do it that way.
