Looks Awesome!
I would be very interested in your pressure sensor and how you went about setting that up! You mentioned briefly in your video something about an oil pressure sensor?
Build looks really good! Like the principal you used for sealing your wires as well!
Ryan
"KR2_Diving"
Work in Progress
Re: Work in Progress
Thanks Ryan!
The sensor is a replacement for an automobile. Unfortunately I still haven't mounted it yet due to limited space inside the otter box, however the plan was to thicken the otter box wall in a small area to thread the sensor in place so the probe is in the water. With that installed the controller has a digital read out displaying the water pressure (psi). My idea was to have a chart next to it with two columns, one for the water pressure and one for the depth. Each row may have increments of 5 feet depending on the DRO's precision.
Anyway here is some more Dive Footage:
fireslayer26
What is the interface between the pressure sensor and the digital display?
I wouldn't mind doing some fishing from there!
WHY using cheap cam for dive and quality cam GoPro only for record?
