Page 2 of 3
Re: Threaded PVC end caps- waterproof?
Posted: Jul 27th, 2012, 8:23 pm
by bikerbones1968
If the jig is a little too tight to spin your pipe knock off a little wood with some sand paper and use wd40 for lubricant if required. The router bit of choice is a 1/2" flat bit. Now line up the outer edge of your pipe directly over the bit ensuring the entire surface will be in contact with the bit and clamp down the jig to your router table.
Posted: Jul 27th, 2012, 8:27 pm
by bikerbones1968
No mater how uneven your pipe is when you start, you will be only taking down the high spots. As you gradualy make the surface flat you can adjust the bit height so that your taking off less than the thickness of a piece of paper. I hope this helps.
Anthony
Posted: Jul 28th, 2012, 1:58 am
by james sowell
nice u should post this in the shop tools thread
Posted: Jul 28th, 2012, 9:49 am
by bikerbones1968
I plan to post the entire build once completed from start to finish in detail. I still have a ton of work to do. I have my DSC radio controller, ESC's, motors, servo for camera tilt, lights control relay, DC to DC LED power supply, video monitor, camera, battery setup all mocked up on the work bench. It looks like a rats nest of wires and components but everything is tested and working. Next I need to make LED light enslosures, motor mounts and kort nozzles for the thrusters.
Posted: Jul 28th, 2012, 9:56 am
by james sowell
cool i got 2 dive flashlights and im going to try 2.4 radio i have camera working
Posted: Jul 28th, 2012, 10:55 am
by bikerbones1968
Does your radio have channel mixing options and does it have DSC?
Posted: Jul 28th, 2012, 11:03 am
by james sowell
its a futba 8fg all the bells and wistles dont know what the dsc is i have 72 mhz also hey do u strip one wire back on the cat5 on tx & rx end did not know if that whould help or not
Posted: Jul 28th, 2012, 12:52 pm
by bikerbones1968
Thats why I asked about DSC function. DSC (direct servo control) equiped radios have a 1/8 jack on the back sometimes called a trainer port. Using the DSC port shuts down the transmitter. The transmitter then sends the signal to the receiver via a pair of wires rather than transmitting over the air. Radio waves dont travel through water very far. I am not sure how successfull anyone has been trying to extend the antenna on a conductor. I have read a few posts on here that they made it work but as far as how well I am not sure. It goes against my understanding of how radio antennas operate so I avoided that experiment all together and looked for a DSC radio.
Posted: Jul 28th, 2012, 1:14 pm
by james sowell
ok i have it backwards then i thought the transmitted signal ran down the wire but yes it has a trainer plug so u just tap into the trainer port ppm i think do u tie it into the rec?
Posted: Jul 28th, 2012, 4:17 pm
by bikerbones1968
With my radio (JR XP6102) the special DSC cord plugs into the back of the radio transmitter and the other end plugs directly into the receiver battery terminal. Mine is set up like this:
