Page 2 of 2
Re: Bilge Pump Motors VS Props
Posted: Jan 28th, 2012, 2:20 am
by NCUWI
I would put the fuse at the power source and then on any sensitive electronics. It's also not a good idea to put a fuse on a ground lead, that can be dangerous. I'd also wouldn't be surprised if your bilge pumps draw more than what they're rated for. Remember you replaced the centrifugal spin wheel with a prop, so there's a lot more load on that motor now than what the manufacturer designed it for.
Posted: Jan 29th, 2012, 8:58 am
by derelicte
the 2.5a rating was for the bilge pump. with a prop on it will draw a lot more. I have a 15a fuse for 3 thrusters. they peak about 12a when running.
definately put the fuse on the positive wire as close to the power source as possible.
Posted: Feb 3rd, 2012, 1:36 pm
by ERIEWRECKDIVER
Thanks for the fuse information. Once again this forum is probably saving me a lot of heart break.
All of you guys are the best. I hope I can return the favor soon concerning lighting.
Posted: Feb 7th, 2012, 8:54 pm
by ERIEWRECKDIVER
One step at a time. $$ I just ordered the props that I need. I am so excited. As soon as they arrive, I will start vertical dive testing with frame design. WO HO.
Look out Koi Fish.
