Page 2 of 2
Re: DPDT Relays
Posted: Aug 20th, 2011, 4:09 pm
by AHarris
Thanks for the help guys, shall speak to a couple of garages and I may also buy a cheap breadboard and just see if they work. If all else fails I may need to turn to it, if I can however get some from a garage then it shall only be a couple of pounds/dollars.
Re: DPDT Relays
Posted: Sep 29th, 2011, 7:50 pm
by NoblePils
thegadgetguy wrote:Yes, those little relays are really hard to work with. I was just wondering about the auto stores/garages because the relays that control the electric windows on cars work pretty well. I found some H-Bridge ones that ran at 12 volts, 7 amps online that I used in my ROV, but you might be able to buy some at a garage or auto parts store. If they don't have them they might be able to order them. I'm not exactly sure how things work over there.
I've searched everywhere for H-Bridge relays online...
Can you please point me in the right direction???
Re: DPDT Relays
Posted: Sep 29th, 2011, 8:58 pm
Here is a relay that might suit your needs:
http://parts.digikey.com/1/parts/749000 ... 2-12v.html
And here is the datasheet:
http://media.digikey.com/pdf/Data%20She ... Relays.pdf
Would you be using switches or joysticks to control them?
