Page 2 of 2
Re: Controlling Depth
Posted: Aug 24th, 2011, 3:57 am
by PSCG
Or, if the parts inside the ABS box allow it without problems, fill it with wax or oil (or something else that cannot being pressured).
Posted: Oct 15th, 2011, 8:05 am
by Chas 100
Rover wrote:I am also using a PWM variable speed control to adjust the vertical thruster for precise hovering ability.
Jim
I with Jim on that, I am using ones from Critical velocity 15 amp bidirectional. commercial rov vertical thrusters are always moving
Posted: Feb 22nd, 2012, 11:55 pm
by Alaska Rov Systems
Thanks for the ideas!
Posted: Jun 25th, 2012, 3:14 pm
by james sowell
which speed controler is easy to get im using the bilge pump moters thanks
Posted: Jul 17th, 2012, 9:37 am
by Rover
On a previous ROV our horziontal thrusters were controlled by relays, but I wanted a way to control my vertical position, so I add a bi-directional speed control I bought from Carls's Electronics......
http://www.electronickits.com/kit/compl ... r/k166.htm
This little kit uses a pot to control speed. I remotely connected the three wires for the pot in my drivers box on the surface. This gave me precise up and down thruster speed.
If you have a PWM signal at the ROV, then a brushed ESC (electronic speed control) is the way to go.
Jim
Posted: Jul 21st, 2012, 6:27 pm
I like that idea.
