Posted: Sep 27th, 2015, 12:13 pm
Hi All,
Yesterday I finished attaching the lower WTC support cradles to the main cross brace/WTC support. I then trimmed a couple of the lower WTC support cradles so that the main cross brace would sit level on my work bench. The upper WTC support cradles did not need to be trimmed.
Today I plan to purchase the marine quality Velcro straps to hold both of the WTCs to the main cross brace/support cradles. I believe that a 36" Velcro strap with a D ring end so that the strap can be cinched up tight around the two WTC tubes should suffice.
I will cut slots in the main cross brace/WTC support to allow the straps to pass through the main cross brace and loop around each tube for a tight fit.
I then plan to start on mounting the four thrusters to the ROV chassis and then move on to connecting the power/control cables to the end cap cable penetrators.
More to come.
SSN626B/TCIII
More to come.
SSN626B/TCIII
