Page 2 of 2
Re: my relay is keep burning
Posted: Dec 25th, 2013, 4:16 pm
by eng.hossam
rossrov wrote:OK, so what are the relay specifications? AC or DC coil, coil voltage. What voltage are you applying to the coil. Or is it the contacts that are burning?
yes,the contacts that are burning
Posted: Dec 25th, 2013, 5:19 pm
by sideshow
You might want to connect an Amperemeter to measure the current.
Posted: Dec 26th, 2013, 1:56 am
by eng.hossam
sideshow wrote:You might want to connect an Amperemeter to measure the current.
it's 5 A and relay can handle to 60 A
Posted: Dec 26th, 2013, 5:44 am
by Oldsirhippy
@eng.hossam
Suggested area to investigate further:
A remaining question from a previous post by Rossrov is what type of motor are you using?
Have you tried a completely different model of motor in your circuit?
If your circuit is OK and your relay specification correct then I wondered whether the burning out of the relay could be due to the type of motor you are using? E.g that the motor is producing a large back emf.
Back emf can produce very high voltages and with the current you are using may burn out relay contacts.
Posted: Dec 26th, 2013, 7:25 am
by eng.hossam
Oldsirhippy wrote:@eng.hossam
I am putting a diodes
Posted: Dec 27th, 2013, 2:12 pm
by CLYON
Are you sure the relay is rated for 60A? That is a big relay. Do you have a part number of the relay?
Chuck
