Does anyone use boat esc's from Hobbyking? I've been experimenting with 30A, 50A and 90A. They are extremely cheap but the quality not so good. Sometimes they break. Sometimes they cannot be programmed. Currently I use 50A esc but don't seem to get the programming right, eg punchmode. When I run the motors I get a lot of power rightaway. In an on-off fashion. Does anybodt have working settings for this ESC?
Hobbyking boat ESC
Silver dollar
Re: Hobbyking boat ESC
The fish is a "Tangsnarre" (danish name). The latin name is Spinachia spinachia
I have tested one of the 30A type and two of the 50A type. All worked fine. I set the programming the same on all three using the corresponding programming board.
And what was your settings for:
fixed area acceleration
start mode
timing set
start mode
timing set
12% fixed area
Level 6 start mode
20deg timing.
Level 6 start mode
20deg timing.
Thanks. I will try that. Also tried a couple of old quad motors I had laying around. 1100kv Turnigy cheap stuff. Seemed to work much better.
