The actuator will be sealed. Only the small metal rod from the gripper will be coming through the case for the actuator. This is the area I will have to seal, but still allow it to move back and forth. Maybe a separate small grease filled compartment.Zaibach wrote:Looking cool![]()
Definitely interested in seeing how the X³ handles. Also the Linear actuator is waterproof or are you modifying one and how much did the X³ and actuator(s) run if you don't mind my asking?
I haven't received the X3 board yet. I will be doing beta testing for the creator when it arrives.
