ROVER3D wrote:the first thing: how to you think you will get it out of the water at a landing-stage 1feet over water-line? how you want to handle it?
why you use a seperate cam-housing and not the centerhousing?
Thanks for the comments guys
I dont entirely understand your first question rover3d but I'll give it an attempt. I'm hoping I can get a chinese finger on the umbilical and attach it to the top/rear of the floatation so I can just oull on the umbilical. I can add handles etc that I could grab with a boat hook if necessary onto the floatation also.
Firstly I wanted to move the camera either above or below the two front thrusters so hopefully there is less disturbance in the picture. This would leave a big space in the center of the rov (I could put the batteries there but they'd be difficult to access and may make the rov top heavy depending on the weight of the batteries.
Anyhoo if it's separate I can move it if necessary, or possibly even attach it to a pan/tilt mechanism. Easily swapping out cameras would be an advantage in the future too. Also, I want to go quite deep so (I think?? smaller housings have less chance of collapsing
Ross: I drew it like that because it looks a bit more appealing I guess. I haven't really decided on how they will really look and will depend on the materials I use.
That said, I was looking at the seabotix ROVs earlier and quite like the style they have:
