ESC?
ESC?
Would i need one for my motors or could i directly wire them into the board? and what if i was to use boat blowers? i saw a thread on the forum that said they worked so im willing to try them
Re: ESC?
I don't think there is a way around using an ESC (electronic speed control) unless you are going hardwired with relays.
Then your control is limited to on/off.
As far as ESC's go be sure to get the right type for your motors. Brushed and brushless motors use different ESC's.
Re: ESC?
is there a way to make your own?
- thegadgetguy
Re: ESC?
Yes, you can make your own. It requires a fair knowledge of electronic theory, though. If you're interested, I've found a number of sites that I could give you links to.
Re: ESC?
yes please, i would like to try! thanks alot!!
- thegadgetguy
Re: ESC?
Are you thinking brushed or brushless? Most of the stuff I've found is on brushed, as brushless ESCs are so common and thus inexspensive that there is really no point in trying to build your own unless you are going for a specialty application.
- thegadgetguy
Re: ESC?
Well, here are some links on both.
Brushed:
This link has some great information:
http://modularcircuits.tantosonline.com ... ch-diodes/
This one as well:
http://www.pocketmagic.net/2009/03/a-si ... Vj1hxyG1nH
Lastly:
http://letsmakerobots.com/node/18633?page=3
Brushless:
the rcgroups forum has a list someone complied with many good links:
http://www.rcgroups.com/forums/showthread.php?t=140454
Brushed:
This one as well:
Lastly:
Brushless:
Re: ESC?
Thanks!
