Current increases as depth increases?
rovdude
Post by rovdude »
Hey, so I have my thrusters that max out at 15amps, which is a conservative rating, because I have pushed them past. They turn 15,500 rpm and have 62 mm carbon fiber props :D , and draw around 15 amps on 12v(at the surface). To contend with voltage drop, I am running them on 18V, which comes to 15V at the other end. I intend to go down to 100 ft (~44 PSI), how dramatic will the increase in current be on my motors?
fluxno
Re: Current increases as depth increases?
Post by fluxno »
what kind of thrusters do you have? is it bilgepump units?, brushless motors?, dc motors without housing?
rovdude
Post by rovdude »
Brushed DC motors in no housing, except a pipe that is held over the propeller, not sealed
fluxno
Post by fluxno »
then the pressure wont affect the motors.
rovdude
Post by rovdude »
Ok thank you! Thats a relief because i already draw a lot
