Best system for a first time rov builder?
what is the best control system for someone who wants variable speed control and a bunch of different functions, but does not want to get into programming? Is there some sort of software that one can download (like steve's)? I would probably want to approach it from a rc hobby grade perspective in terms of electronic speed controllers and servos, since i have experience with that. thanks.
Re: Best system for a first time rov builder?
if you use a RC remote and receiver and give the antenna its own line up the tether it will work just fine
Never prototype
I'm about elbow deep into a similar path with my rov/sub and I can tell you there are some challenges going that route. If you are going with an umbilical and many functions at depth use adino this article is a great resource
http://m.spectrum.ieee.org/geek-life/ha ... rsea-robot
I 'm trying to build what is essentially a sub with a camera on it and I'm using a rc setup like you want to do. I ordered a wireless video transmitter and I'm going to try putting that and a spectrum receiver satellite on a bouy attached to the sub of course. Check out mikes subworks if you want to go this direction. I have a dxi 6 and I wish it was a dxi 14 for this build.
I bet you can put gimbals on an adino. You should look into that.
Alaska Rov Systems
Yeah I have also decided that if i was going to do a camera system, I would go with a wireless camera and attach a wire from the antenna on the camera and have it go to a buoy on the surface, hence what we discussed over the phone. I believe this would work but of course have not tested it yet.
Alex
Alaska ROV Systems
Alex
Alaska ROV Systems
I've been toying with the antenna on the buoy idea for my next build too. however I plan on using wifi, not rc and wireless video.
one disadvantage to the wireless approach is you lose a nice safety feature inherent with a tether - the ability to recover the rov in the event of a failure, low battery, strong current, etc.
For a recovery solution, I was thinking of using something like a fishing rod attached to the buoy as an emergency recover mechanism.
Alaska Rov Systems
Funny that you mentioned recovery, I was thinking of attaching a piece of strong fishing line to the corner on the frame to recover the ROV. In the case of complete failure, I would reel in the fishing line and retrieve it.
Alex Stuart
Alaska ROV Systems
Alex Stuart
Alaska ROV Systems
Never prototype
Mikes subworks and other rc sub sites carry really cool failsafe circuits that operate a servo or in my case a ballast pump in case of signal loss. Less than 15 bucks and they don't take an extra channel either, a must have.
