hello everybody new to the forum & my first post although i have been following homebuiltrovs for sometime, i have been mucking about with my rov for a long time now and have finally got to a point where i am trying to sort out the controll side using the Velleman board, I have an arcade type joystick for forward and turn control, but i am struggling to get the wiring to work, i origionaly orientated the joystick so that forward activated 1 relay, reverse 1 relay Left turn Right turn 1 relay each when i had cotrols set up origionaly on cat 5 i made a diode setup to enable this to work the 2 thrusters with the various forward & reverse as required for the maneuver, but i decided i wanted to reduce the cable down to a 4 core for video and control, and used the vellemen to achevieve this... however the setup will not work unless i rotate the joystick orientation thru 45deg so that forward operates 2 relays etc...... my problem is this does not work very well and more that often i only get 1 relay working even after adjusting them as best i can.... is there anybody out there who has had the same problem and managed to solve this??
sorry for the long spiel hope someone can help
cheers
Jonny
another Velleman K8023 question
Re: another Velleman K8023 question
I may have solved my problem i can get a dual post joystick from rs components see link below, so i will purchase and let you's know how it go's.
cheers
jonnyh
http://uk.rs-online.com/web/p/joystick- ... s/3986749/
cheers
jonnyh
