Looking for an easy way to control my ROV
bigdavevw
Post by bigdavevw »
Hi guys, i,m looking to build my first ROV to explore mines/quarrys. I dont want to be messing about with circuit boards/programs etc, i just want good ol fashioned switches.
I,m after a system that will be really easy to build, maybe i will upgrade to a joy stick when i know a bit more about how it all works.
I,m planning on using a 12v tractor battery to control the ROV from the surface so the switches will need to be be quite heavy duty
Dave
bikerbones1968
Re: Looking for an easy way to control my ROV
Post by bikerbones1968 »
Hi again Dave, you can't get any simpiler than to use DPDT (double pole double throw ) momentary switches. They are inexpensive and can be bought anywhere. Using them you can have full control forward and reverse up and down. Like these http://www.ebay.ca/itm/6-Pin-Toggle-DPD ... 1c1ef05145
The link below will take you to Steves main site where he details how they work.
http://www.homebuiltrovs.com/howtoswitch.html
Anthony
bigdavevw
Post by bigdavevw »
Thanks Anthony :)
bikerbones1968
Your welcome :D
Saab340
Post by Saab340 »
How could I wire this if I have 7 hot lines and one common ground line, and only one ground and hot from the battery? The 7 power lines come from each of the 4 bilge pumps, 2 lights and 1 12vDC motor to turn my grabber arm. This one has been sumping me. I'm using 14 gauge wire due to the voltage drop and this is enough of a gauge for the depth I want to go.
soulreaper
Post by soulreaper »
I was going to use relays in my controller, but I used Normaly opened/ Normaly closed switches, instead. They are cheaper than relays. My controller has alot of buttons, but that is because my rov can move 8 directions.
