vellman K8023 10 Channel 2 Wire Remote Control Kit
How to use vellman K8023 10 Channel 2 Wire Remote Control Kit on a mate scout class rov? Would it involve programing and what whould I use for the surface controll? I would want to control 3 motors, manipulator and lights :geek:
Re: vellman K8023 10 Channel 2 Wire Remote Control Kit
K8023 do not require any programming.
On surface you can use normal switch. And relay on the ROV.
How would you wire it to the relays :geek:
Output is ground. Connect positive on one side of the relay and the other to the output of k8023.
Usermanual:
http://www.velleman.eu/downloads/0/illu ... _k8023.pdf
Usermanual:
