sort of. differential serial (rs-422/485) can operate up to 1200m. ethernet's twisted pair limit is 100m. rs-232's practical limit is probably around 50' or so.chriskon149 wrote:Also, two Arduinos should be able to communicate over UDP using Ethernet shields, if that is what you're interested in, without the need for a computer in between them. That should (correct me if I'm wrong) let you use a longer tether than serial.
Chris K
however for the lengths we are talking about for our purposes (say 100 - 300'), either interface is fine. but serial is far simpler and less expensive.
