spdt switches
spdt switches
If you are using spdt switches do you have to use relays on the rov?
Re: spdt switches
Depends on the purpose of the switch. If you have a switch topside and use that to flip the powerline to a motor for the direction then not. But if you have the switch connected to an arduino then you probaly need a relay to switch something in the ROV.
