Waterproof Live Feed Camera Suggestions
Posted: Dec 6th, 2018, 9:30 am
by JFindlow
Hi! I am planning on building an underwater ROV and would like to attach a waterproof camera that can provide a live feed to a laptop on the surface, ideally with an HDMI cable. The ROV will most likely be traveling less than 20 meters. I have done a decent amount of research and haven't found any cameras that fit what I'm looking for. As far as price goes I would like to spend $130 or less. If anybody has any suggestions please let me know.
Thanks, Jake
Re: Waterproof Live Feed Camera Suggestions
Posted: Dec 10th, 2018, 5:44 pm
by PhilA
You could possibly use any action camera or Dash Cam with a RCA or USB output and then get a USB to HDMI or RCA to HDMI adaptor to plug it into the laptop. You would still have to waterproof the camera or the where the cable penetrates the waterproof housing.
Posted: Dec 12th, 2018, 9:40 am
by JFindlow
PhilA wrote:You could possibly use any action camera or Dash Cam with a RCA or USB output and then get a USB to HDMI or RCA to HDMI adaptor to plug it into the laptop. You would still have to waterproof the camera or the where the cable penetrates the waterproof housing.
I'm mainly not sure how I can make the camera waterproof while still giving the camera full visibility in the water. I thought of some ideas to make it waterproof, mostly by using threaded PVC, but I'm not sure if this is the most practical way. If I can find an action camera that has a waterproof case with hdmi access that I can buy then I will be set.
Posted: Dec 12th, 2018, 8:51 pm
by Ian MacKenzie
This is PVC fittings from Home Depot.
Posted: Dec 15th, 2018, 6:19 pm
by PhilA
I don't think there would be any low cost camera that would have a waterproof HDMI port to provide a live feed whilst submerged. There are a few low cost action cams that come with a waterproof acrylic housing which you could fabricate a connection through but then accessing the camera and SD card may be a challenge.
