novice from Spain
Posted: Mar 5th, 2018, 4:47 pm
by asesorplaza1
I just registered to this forum, although I had consulted it several times, it seems very interesting to me everything you publish, and it has given me some ideas, to see if I can help you finish my ROV, I have it half, then I I count to where I have arrived, a greeting to all.
Is there any other partner from Spain?
Re: novice from Spain
Posted: Mar 6th, 2018, 11:33 pm
by leeinmt
Bienvenidos. Te tenga suerte.
Casi todo aquí esta en Englis, pero hay maneras de pasar la pared de las idiomas. Perdón mi gramático del Espanol, pero mi idioma original es Englis.
Posted: Mar 7th, 2018, 7:35 am
by asesorplaza1
no te preocupes, ami me pasa lo mismo con el Ingles, tengo que traducir con Google, el idioma no sera un problema, un saludo
do not worry, the same thing happens to me with English, I have to translate with Google, the language will not be a problem, a greeting
